When closed the handle points to the passenger side [3 o'clock position], turn up to open.
Ron
Yep! Turns out the handle will only lock if starting from vertical (tail pointing up) or 3-o'clock(-tail pointing to the right. ) when locked.I picked the latter. Thanks for the help.Have you tried fitting the handle into the latch assembly? For it to function correctly, some of them can only be installed one way. When the key is turned in the lock, a plunger engages a notch in the latch housing. If the handle is not installed properly, that will not happen. I have seen some latch housings that have two notches, allowing for more than one handle locking position. But if your latch only has one notch, you will only have one choice for mounting the handle.
Thanks.Glad to see an original.picture of my original
On my black, 29 coupe the closed trunk handle points down. On my 31 sport coupe the rumble handle points toward the rear
