Lamar Wadsworth
The Summit site is confusing as to which Pertronix unit fits the '57-up Y block distributor. Anybody know which # I need to buy?
I've used the Ignitor I for yrs even with a junkyard coil. Pertronix will tell you how to pick a coil that will work, if not using theirs. thing with Ignitor I is you can't leave the key in the "on" position as the module can burn up if the dist. is in a certain spot. I installed a plug in the wires going to the dist so I could work with the key on because our '41 w/ 302 had no acc. position on the ignition switchMake sure you get the Ignitor II version, and the recomended Pertronix coil to go w/it.
we saw a pic of our car in a buffalo paper sitting in a field in Sweden,ny in a snow storm(2016). I think it was an article called "old cars in western ny" or something like that. It then went to cortland,ny, then to spencer,ny briefly and then we bought it in 2018. northery ny winters didn't do it any good! someone put some good $$ in the interior. a few rust holes on fenders but floors were like new after we cleaned decades of dirt, tar and oil off. 292 runs like a top. repainted sunburst copper w/ white topYes, I too had a Ignitor I for yrs. in my '57 Fairlane with no problems. Then I had the ignition switch "on" for a bit while wiring up a new radio.
And, well, you know the rest of that story! Good idea installing a plug on yours to disconnect the distributor. Yes, you don't have to use one of their coils, as long as you use one w/the right ohms specified for your application. - F F
BTW - I remember seeing your '60 when it was for sale 20 yrs. ago in Brockport NY!
'57 & up = 1281The Summit site is confusing as to which Pertronix unit fits the '57-up Y block distributor. Anybody know which # I need to buy?
