another easy comp check is to see if it will run on 1 cylinder before you go out to the store and get all this stuff. Start your car up, bring the throttle down a little, pull the spark all the way down. Then grab a screw driver, and slowly take each spark plug wire off one at a time, utill you get to the last one. You may have to give it a little more throttle as you go. But if you get it running on one cylinder and it stays running, you comp is good, at least you valves are in decent shape and your rings are sealed. then do this test to every single cylinder. If you get one cylinder that just will not run like this, or runs way worse than the others, that is your problem cylinder. Most people dont beleive a model a will run on one cylinder, but it will lol ive done it mulitiple times. try it, see what happens. BTW, dont take of the cylinder wire, untill you have the next cylinder wire already hooked up, because then it really wont run lol. It wont take more than 5 minutes and it sure beats 30 minutes on phone calls with part suppliers, or 15 drive to the store to get guages.
