Where to get gas tank?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I need to clean the tank in my '47. The eastwood kit is about $50 plus extra supplies you need locally. I was talking to the PO who said he had that problem years ago. Thinking now maybe I should drop for a new tank. Hoping for something under $200. I see drake's got em for about $250. I don't have that to drop on a gas tank.
Can napa get em?
Tanks Inc. has poly tanks that may be cheaper
320-558-6882 Clearwater, MN
If you tank is not rusted out, get the gas tank repair kit from POR-15. It contains everything you need to fix your tank where it will last longer than you will. First step is the Marine Clean compound which gets rid of the rust and cleans down to bare metal. The next step is a solution that etches the metal where the sealer will bond to it. Final step is the sealer. Do it exactly by the instructions and you will have no more trouble with your gas tank.
where do you get the por15 kit?
I've seen por 15 gas tank sealer, but never a full kit from them. Who has that, and what does it run? If I gotta lay out $100 just to clean mine, I'll go for new at $250.
SAcramento Vintage Ford has the Por kit in stock, just bought one
I got one from bob drake and it was beautiful. but the gauge has to be one of his.
I do have a new one if you need it ,price is $ 25.00 ? his is $ 35.00. so if you need it let me know .OK Thanks Mark
I got a tank for my 41 pickup from Drake, but I used the sender I got with my Auto-Meter guages.
