Drill one in the front of the manifold. Find a grommet, drill to suit and PCV of correct size to suit the engine capacity. . You may need to come up with a baffle on the inside if you think it can suck oil..[?] . Hole under the carb drill or use a vacuum plate. Block off the draft tube. Make sure it can still and breath from the vent cap.
Yep. That's why I suggested that Mumpsimus forget the valve altogether. Just go passive entrainment in the engine compartment if cabin stink is the problem. Jack E/NJ
Thanks, that's good to know.None of that discussion applies to a 59ab or 8ba, they have a rear main seal.
