Pat Martone
I happened to notice that engine valve side cover oil return pipes (tubes) do not seem to be available from the vendors. Everyone seems to have the gasket sets, but the not pipes. Does no one (not even A&L) make this item?
Could it be that the only way to get an oil return pipe would be to find an original at some place like Bert's Model A parts in Denver?
I am asking because I am curious since noticing that my pipe is leaking oil at the upper end of the pipe, not where the tube is soldered to the "cup" but where the "cup" actually meets the valve side cover. I have replaced the gaskets 3 times, and I did not overtorque the bolts, and I tried both the paper and cork gaskets and used both a little bit and also a lot of Permatex number 2 gasket sealer. It still leaks a bit and I am wondering if I should buy another oil return pipe but couldn't find one available from the vendors. Perhaps I should trying installing the pipe again, this time using the cork gaskets and soaking them in motor oil before installing instead of using Permatex gasket sealer?
Just curious; thanks.
