Stillrunners
someone rebuilt this 2N motor and didn't redo the oil pump - had no oild pressure - checked ALL the lines then went after the pump - it will not pull light oil off or on the motor - we pulled the crank gear and ran it with a drill with a magnet dilly we got at harbor frieght....it will blow oil out of the bowl of oil running backwards but won't pull up through the tube.....we've had it apart and the shafts seems to be close enough in tolerences according to the book - not sure about the gear.....get a new oil pump kit?
