1crosscut
What would be the point of running the bowl empty?. To my way of thinking there is no way fuel can leak once the valve is closed and there isn't anything in the bowl that could be negatively affected by fuel sitting in there, even for extended periods so, why run it dry?.
Every once in a while on hot days after shutting off the engine and then restarting a short time later I have had some rough running issues for a minute or two. I figured what was happening was the fuel in the bowl and first bit of fuel line got hot due to no air flow / fuel flow and perhaps boiled causing the temporary running issue. Now I shut off the fuel and let it run for a bit when stopping for short times on hot days. This allows fresh "cold" fuel run into the carburetor for trouble free restarts.
I always shut the fuel valve off and let it run dry when parking over night etc...
