modelacarman
Is it possible to weld cracked wheel rims? Or will they crack again?
Clean good! Depends on the area have a picture! Year. there is plenty of rims out there.
Forgot about Australia!! Sorry.Now that depends on where you are. Good wheels are a sought after commodity here. I've repaired some and seen some shockers on the road. I've not had much luck repairing them except when I decided to make them stronger. I kept cracking them while towing and repairs didn't get me far. Once home, I had a profile cutting company cut me some rings out of 3mm sheet. ID was 270mm and OD, 290mm. That gives me a 10mm wide ring all the way around the wheel centre. Pry the rings on, a couple of welds to hold it in place and I haven't had one crack since but it causes the failures to move to the next weakest place - pulling the spokes off the rim.![]()
CW Pasedena has it right !! They can be repaired by properly prepped Tig weld I've done a few that way with good results
Here in the UK good wheels are not always easy to find
Best to consider the condition of the rest of the wheel before starting though .
Those that have oversize wheel nut holes , badly rusted rims especially the 21"s,
lots of missing spokes, or greatly out of true ,might not be worth repairing IMO.
I've often wondered why did they crack ?
Loose lug nuts, miss match late wheel on AR early hub,
or mounted on a later hydraulic hub without the adapters
What does the team think ?
A cracked Model-A wheel can be welded with a MIG by a competent craftsman.
Something to contemplate though. Suppose someone poorly welds a crack on a wheel and the wheel is driven several thousand miles before the crack reappears. Has anyone ever seen a Model-A wheel disintegrate because of a crack?? From what I have seen, -and by the way most hobbyists drive, when a wheel crack does appear, it is usually not critical enough that the vehicle cannot be driven home if care is taken.[/QUOTE
I have never seen a collapsed model A wheel that wasn't caused by a wreck! Proper welding should last many miles.
Coker tires have new wheels, but boy they are pricy!
