19ED30
Did a search did not find what I was looking for ,
On my 32, ( I did not Restore / 1950 Modified Build ) I removed the hub caps and found that the studs are .150 thousand to short from even coming flush with lug nut , only .350 worth of threads used , so at least .400 to short of a stud ,
The wheels are 16x4.5 and 16x6 Gennie replacement wheels ,
Front hubs and brakes are 40 Ford ,
Rear hubs & rear is 32 Ford
Any one else run into this ,
Did fords with none wire wheels have a longer stud , or aftermarket steel wheels thicker?
