Ford Barn has posted a warning earlier, do not use repro' wheel nuts, I found it out the hard way last week. Left rear wheel fell off, all my repro' nuts gone, put it back on, a big mistake since the holes were worn, it fell off AGAIN as we neared home.
I've since bought a good wheel, also a good used hub/drum, that was a hundred bucks, also a dozen original Ford nuts on eBay, another 40 bucks.
My advice: Do NOT use these repro' nuts, they are not recessed to accommodate the nub on those studs, stud threads do no go all the way to the drum, your wheels will not be tight, even tho' your nuts seem tight.
I'm not the first one to have this happen, don't be the next, find and use only genuine Ford wheel nuts, toss those repro's in the junk.
Warrene
Warrene
