On a modern of mine I had new tires installed, after leaving the shop it felt like a wheel was about to fall off. I immediately returned to have the nuts checked, the manager using a toque wrench said they were tight, I followed him and turned the nuts tighter by a half a turn or more. Not all toque wrenches are correct and maybe their chart was off. The looseness that I felt was gone but at highway speeds I felt a bad vibration, at home I found one wheel had weights 3/4 around the wheel???? I took the wheel back and another person rebalanced the wheel and only put one weight on. I tighten all of my lug nuts with an 18 inch breaker bar by feel, it’s not good to loose a wheel at any speed. The hand cranky thing isn’t good for tightening wheel nuts and also dangerous for hand starting, it’s only good for turning over your engine to find the timing. Get cross lug nut wrench or a breaker bar to tighten your lug nuts . RANT OVER
P.S. snug your lug with the wheel completely off the ground, then lower the wheel to the ground and final tighten the lug nuts in a crisscross pattern
