My new 34 has an iron overdrive unit welded (very neatly) into the drive shaft in front of where the radius rods tie in.Cast into the side is W G DIV n2. Under the dash has the electric switch and 3'' lever to actuate. The hot wire to the battery is disconnected. Can you tell me what kind of overdrive this is? How does one operate this?Manuals must be out there. Shall I just flick the switch an pull the lever while proceeding slowly down the road? Tempted to start playing around.What weight oil should be in it? Car has been a storage for a couple years.What ratio might this overdrive be? The differential gear is a 4:11. The car has the standard 600x16 tires. Thanks for any advise!
