What's this piece called..
I need to replace these rusted metal pieces that are in the upper rear door jambs ( rt and lt) on the main body of my 1930 4dr murray TS. What is the piece called ? Does anyone know where to get replacement pieces?
Not sure what it is called, i had some like that and sanded down the rusty ones. Someone else is the past had made new ones from galvanized roofing steel. If you cannot make them a metal shop should be able to fold some cheap enough if you do not mind cutting the little slot/spaces for the nails yourself, shops charge heaps for fiddly work like that for some reason.
