I have owned a number of Fords, but have never really been a "Ford guy". Consequently, my knowledge is pretty much limited to the specific Ford products I have owned.
I went and looked at a 1966 Comet Cyclone GT today. It was a pretty nice car. But, it needed enough little stuff here and there I decided I didn't want to make a deal until I knew a little more.
I have no idea if it is a genuine GT or not... if someone can enlighten me how to tell, I'm all ears.
Car was originally silvery blue with a black interior. It has been painted black now with the exception of a few minor scratches and 2 or 3 small bubbles, it looks very good. The bubbles are very small(BB size) and don't appear to be rust... yet anyway. They look more like moisture has gotten in between the paint and the primer. Body is not 100% perfect but looks pretty straight... especially for a black car. 95% of people would say the body looks great. It has had the bottom of one quarter behind the wheel replaced and a couple patches on the inner rockers/trunk floor extensions.
The floor has a couple of dents in it. They're not deep(maybe only pushed in 1/4" to 3/8" of an inch. The worst thing bodywise is that the car appears to have sat in a damp environment at some point since it was redone and there is rust starting here and there on the floor/trunk pans. It is not bad at this point. I'm sure it could all be cleaned up with one of the Roloc scotchbrite wheels.
One tail light lens has a crack. and the tail light bezels are pretty hazy, but not broken or bumpy. The rest of the chrome is pretty good.
The interior appears to be original(with the possible exception of the headliner and carpet. It has buckets and a console. The console is broke on the drivers side below the chrome trim. The driver's seat is slightly broken down. But, not bad. Upholstery is all good. All dash lights work except one signal indicator. Aftermarket stereo in the glove box.
Glass looks good.
As I said, I am not sure if it was originally a Cyclone GT. It is currently a non-numbers matching 390 with a 4 speed. Motor had a ton of work when they restored the car years ago. I can't recall all the specs, but I'll relay what I can. It's got a not huge but decent aftermarket cam. Can't remember the code on the heads, but according to the builder they were factory performance/desireable heads, Pertonix guts in a Ford 428(?) distributor, Ford aluminum intake(also from a 428 I believe), aftermarket 4bbl carb. Dual exhaust. 3.89 open rear end. Radiator didn't leak when I looked at the car, but has a small area with that green corrosion that would indicate it has leaked at some point.
Also, as a point of reference, this guy will work with me some on price, but he doesn't really care much if he sells it or not... he was actually responded to a wanted ad I had placed for a 50s to 70s car with a 4 speed.
So, what do you guys think is a fair price?
Glass looks good.
