What's in your toolbox?
He is referring to the hand crank, which is the only original tool still with our 'A'. It is the most important one too. Mine was used almost every day during my senior year in college, as the battery was just a hard rubber case full of water!!!
Hand crank, screw driver, feeler guage, oiling can, wreches from 3/8- 11/16 vice grips, pipe cleaners, some bailing wire, condencer, and the most importaint tool (a pair of ladys nilon stockings) For if your water pump seizes up you can make a belt fromthe genny to the crank ( all i needed on my trip to canada). This weeks trip though the white mountains i used my hand crank; the only other tool i used was a screw driver to pick my teath after dinner haha
anyone mention an instruction manual?
I guess my picture wasn't "worth a thousand words" :D
picture.php
For flashlights I recommend Pelican brand. I have many including a few headlight versions like the 2670 that ******** my head so I can work in the dark. My favorite normal light is a model 2360. All use normal batteries and are super bright.
I also have a Pelican 7060 which was a $120 flashlight from a few years ago, rarely use it though as the cheaper 2360 is almost as bright and much smaller.
For tools, two quality adjustable wrenches, spare points, spare fuses, headlight bulbs, spare coil and of course a decent multimeter.
MODEL A TOOL KIT​
FRONT TOOL BOX ​
Wooden cheese box
Clothes pins
Distributor wrench
Door hinge pin
Fuses-30/20 Amp
Goop/duct and elect. tape
Ignition Switch bypass
Misc. wrenches/Feeler gauge/screw drivers
Muffler seal
Point file
Short Phillips screwdriver for timing
Spark plug wires
Tire weights
Tube repair kit
Wire
Brake switches
Bendix spring
Carburetor
Clutch release arm
Coils-2 + wires
Compression gauge
Cut out Switch-2
Distributor drive gear and spring
Exhaust Clamp and gasket
Fan Belt
Fuel line & filter
Float adjustment tool
Funnel
Gallon of H2O (on running board)
Gas cap
Gasket seal
Grease gun
Glue
Ignition harness cork and nail (replaces bad switch)
Instant Beer
JB weld
Leather belt (Bearing replacement)
Oil
Misc nuts, bolts and washers
Multimeter
Polish
Rags
Rod bearing cap
Rubber gloves
Safety wire
Springs
Spritzer
Starter switch
Timing Gear (socket and tool in tool bag)
Timing Pin
Vacuum hoses
Voltmeter
Water pump and gasket
Water pump grease
Wheel bearings-1 sets
Wheel bearing Grease
Package tray​
Batteries
Business cards
Bratton’s catalogue
Flashlight
Fire Extinguisher (on running board)
First aid kit
Good luck charms
Hand wipes
Light bulb box
Model A club Roster (in door pocket)
Repair manual
Snacks
Walkie talkies
UNDER SEAT
Plastic Parts Box
Accelerator return spring
Ammeter-2
Axle key and shims
Axle nut remover
Carb gasket set plus needle valves
Condensers and Points
Gas filter screen and glass gasket
Generator brushes
Distributor cam and cap and top/bottom plates
Engine bearing shims
Exhaust gasket
Hose Clamps
Light Bulbs
Plug wires
Rotor
Spark plugs
Speedo gear
Starter bendix bolts
Water pump packing
Wheel nut washers
Wire ties
Valve and guide
Cotter pins
Crank
Distributor body
Fan belt
Gas gauge repair kit and tools
Jack
Lug wrench
8x10 Glossy of Sandy
Stethoscope
Tire tube
Tow rope
RUMBLE AREA​
American flags
Blanket
Bungees
Calico chicken
Chocks
Distributor
Flares
Folding chairs (sometimes)
Headgasket
Hose set
Paper towels
Pancho
Torque wrench
Tool bag
