===============================================6 volt negative ground.
To check the state-of-charge or find bad individual cells in a battery there is a DIY tester...
[/URL]
be careful when charging a battery indoors, they give off hydrogen gas which is very explosive. you have heard of the Hindenburg right? batteries with bad cells and ones with sulfated plates sometimes will not take a charge but will boil the water out of them giving off the aforementioned gas's. good batteries can also give off the gas's if overcharged, or charged at to fast a rate.
What voltage was the 1955 ford customline? I'm trying to charge my battery and don't want any issues.
Yep, but I didn't want to break the spellchecker.Commonly known as a hydrometer...![]()
3 cells = 6 volt, and 6 cells = 12 voltCount the cells, should be apparent. But I'm not a battery expert....
This was common in the late 50's and 60's, but the regulator must be reset to properly charge the eight volt battery.Yep, but I didn't want to break the spellchecker.
If you want to really confuse the situation some folks use four cell 8 volt (tractor/specialty) batteries in their 6volt cars for a bit more kick to the starter, and you don't have to change bulbs and other things on the car, so it's an easy non-conversion conversion.
Thank you everyone who helped. We got my 55 started yesterday, now we start on the brakes.
Hello my name is Alexander, just wanted to know what you ended up doing to get your car started. 6volt positive to ground or what was the fix.
