What type of PCV valve Flathead ford
ethov8
I had 2 replies to my first post. Thank you, I think its part solved my problem.
Much appreciated.
Next question.
I need to source a pcv valve to suit my motor. Its a 266 CI modified producing I guess about 140/150 hp. I need a PCV valve with a thread on it which will be compatible. I need a manufactures number like Fram or other that I can source in the UK. To quote a pontiac v6 or chevvy small block wont work because we dont have them this side of the pond. I have noted from a previous post that a Fram FV294 will work but no thread on it, so I would have to glue it into the manifold. Not too keen on that. Fram do a FV345 this has a thread on. Would this be compatible. Your input again will be much appreciated.
Cheers fellas stay safe have a good weekend.
Marcus
This is the setup I am using on an 8BA./8CM.
picture.php
The last one I did I used a PCV from a mid 80's Ford V-6. Worked fine.
