My advice is to skip installing any Thermostat. At some point down the road, it is going to fail, ...and the stress/damage that it will potentially cause you is not worth any benefit you might have felt. If you want to quickly warm the engine, then just after starting only slightly advance the Spark Lever during initial warm-up. The retarded ignition timing will allow the temps to rise quickly. Allow the engine to operate at a fast idle with the ignition timing retarded and you will see the coolant boil in just a few moments. That likely out-performs what any Thermostat can do.
More owners should take this advise!
Enjoy
