Tom Wesenberg
Many people can benefit by thinking of electrical flow as water flow. The hose is the wire and water is the electricity. A switch or faucet can stop the flow, and you need a return wire or hose to complete the circuit. A water pump is like a battery supplying the source for flow and a hose retuns the water back to the pump. The water can do work such as turning a turbine, then return back to the pump, the same way a wire (or car frame) completes the circuit for return of electrons.
More water pressure is like more electrical pressure (volts), and more water flow is like more current (amps). Compare the water flow of a garden hose to a river. The water hose can have high pressure but not a lot of flow. The river can have low pressure but a lot of flow and can do much work. Think of the heavy current to run the starter, but it's low voltage (electrical pressure) is to weak to jump an air gap. The heavy current can do a lot of work like cranking the engine. The coil is low current but high pressure. It's pressure is high enough to jump a large air gap, but the current is too low to do much work. It takes a good flow of water to run a grist mill or electric generator and it takes a lot of current to run the starter.
You can also put a one way valve in the water hose so the water can flow in only one direction. A diode is a one way valve for electricity and allows the current to only flow in one direction. A water valve or electrical switch can stop the flow in both directions.
