WHAT power brake booster conversion to use
38 Conv
Looking for ones who installed a power brake booster conversion firewall mount kit on their 1953 to 56 Ford F-100, what Company did you use Speedway, CPP, other--and any installtion problems and is pedal height to HIGH from firewall and floor, any pictures would help-- Thanks
I installed this kit from Mid Fiftys in this '55. Truck not yet completed but kit is easy install and comes with template to locate it. Had to fill a couple of holes behind it. Everything appears to fit correctly and I don't anticipate any problems. All valving is done, no residual valves needed. Pedal height seems fine.
Hope this helps.
Dick
