What plugs are you using?
01aford
I've been using Champion H10's and I'm thinking about trying another set.
What are you guys running in your 85 hp Flattys?
Using Autolite 216's right now. Just got the 38 pu running 3 weeks ago, still not drivable so I have not done a heat range check on them. I prefer autlites for most applications as apposed to Champion's. Rod
I use D-21 which is a hotter Champ for 18 mm engines.Will not fit in H-10 engines.Been using them for 20 odd yrs. Tried 1 set of NGK's and deep 6th them within a month. ken ct.
Ive been running NGK B4-L's. Ive had the same set for over six years. Just replaced them with a new set. Been working great on a mild 8ba with 2x2's, cam, and a unilite dizzy.
I am currently using the Autolite 216 also. No problems to report. I like the black base which is what the original Champion H-10s had. Pat
