what makes a t Jump
John Duden
hi fellas,
Im fixing a 24 t coupe for a friend. When you push the clutch pedal down into low it engages as it should, after i get it moving i let it out into high like normal but the tranmission "jumps" or "slips".
has anybody else had this happen? How do i correct it?
Thanks
John
In my T when "shifting" from low to high, I pretty much close the throttle all the way to get to lowest rpms. Also start out in low with spark slightly advanced, then shift into high, then advance spark once in high. Helps avoid the lurches and shakes.
