snappydon
After a 2 year hiatus I'm back on my '37 1-1/2 ton project.
I've got all the old tacky/sticky lube out of the 4 speed transmission and rear differential.
But what should I put back in ?
I keep reading about 600w grease/oil, 00 grease etc but can't seem to find the definitive answer.
This truck is all original, won't be cruising down the hwy. Just puttering around at local cruises and a parade now and then.
Want to prevent as many leaks as possible.
I know with farm equipment we frequently used 00 grease for gear cases and boxes that were prone to leak past the seals when sitting instead of 85-140 gear oil etc.
Would 00 be acceptable in the transmission or differential?
