What is this ?
jtminor
1951 Ford F1 what is this for?
FYI, The compression fitting is not only unsafe within the brake line, it's illegal.
There’s already two lines coming out of the block in front of the brake light switch.....I wonder what the line with the compression fitting is for.......Mark
I think that the line with the compression fittings goes to something else other than the master cylinder. Hopefully the OP can tell us where it goes.
Maybe like TJ suggested, it's just something not plumbed into the brakes at all. Maybe an oil filter or pressure gauge line taking the long way around?
