What is this body part called?
I need some help here guys.What is this body part called? Is it the same shape from 28 thru 31? And finally is it the same on the roadsters, coupes, and any others?
Thanks I need to find a new one or at least a good one and have no clue what it is called? Thanks again it is appreciated!
Part # A-40054 - Rear floor Cross Sill Assembly was the official Ford part number/name
Same for all Coupes and Roadster from 1928-31 with the exception of the early 1928 versions which had the three threaded inserts on the left end (as shown in your picture above) for the tail light bracket.
Bratton's calls them the "Rear Body Cross Member" as H.L. indicated above - look in the "subrails" section of their catalogue.
Also sold on eBay: http://www.ebay.com/itm/260915925910?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
I have a decent original if you're interested PM me.
Thanks guys for the response here... I now know what I'm after! :D
I sent you a PM Randy as I'm looking for and original in good straight working order. I will be using this price to build Roll Pans off of on the bench insuring the fit is correct. Thanks again
