81T heads were installed (originally) on the Ford engines.
It would possibly help folks to at least have an idea of what these parts REALLY are if they would put some effort into learning Ford's early parts numbering system. Numbers like "81T", "81A" and "99" actually signify some pretty basic, yet revealing information. The "81" prefix indicates two things........"8" (the first position) indicates 193
8 as being the FIRST year of release for that specific part. The "1" indicates that it is a FORD part specifically (and POSSIBLY also used on Mercs
IF the Merc uses an identical part, although Mercs didn't initially appear until 1939). A better example would be 1940 brake pedals. A FORD pedal would have an "01A" prefix, where-as a Mercury would have a "09A" prefix on it, as they were slightly different in design. The "T" (81T) indicated that it is a part for a "big"
Truck......NOT a pick-up, which would be indicated by a "C" (81C) for "COMMERCIAL", which a 1/2-ton pick-up falls under. "81A" would indicate a 1938 (8) FORD (1) PASSENGER CAR (A).
So, what is this "99" stuff? Well, the FIRST "9" (REMEMBER: First position) indicates 193
9 as FIRST year of release. The SECOND "9" indicates that it is specifically a MERCURY part. Once you start recognizing these numbering sequences, you can begin to at least start guessing pretty-closely as to what some of these common parts are. DD
