what goes here?
dronedog
30 sport coupe. this is the door jamb. looks like some sort of bumper should go here. you can push in the center part. it has a spring behind it.
wanted to order 2 for the car.
thanks
I don't think that is an original part. I have never heard of a Model A coming from the factory with a door jamb light switch.
I read a post a while back where one of these switches was used to set off a buzzer in case you left your lights on and then opened the door.
If there are no wires attached, it may just be a door popper, meant to help open the door, or stop rattles from worn hinge pins. Our roadster pickup has similar buttons, and I think they were installed to stop rattles.
Yep, that would be my guess as to what it is. Lots of after market gizmos from way back when to help separate the working man from is money. Of course none of that goes on these days. :D
well i looked behind it as best i can and no wires or anything that makes it look like some sort of switch. the very center of this is threaded like a stop or bumper screwed into it. there are no screws holding it on as you can see.
i figured it was something to help keep the doors from rattling also. not sure what "poppers" are or how they are mounted. Maybe someone could post a pic.
Thanks
