Now that you have fixed your choke, I would clean those plugs up and then drive it some, and check them again.
Use a small brass brush and clean that soot off, then set the gap to .035
When they run rich the plugs get sooted up like that.
If the mixture is just right the plug will be more gray in the center area.
You know it was running rich because it was smoking, and that may have been because the choke plate was partially closed...
