You are correct. Marshall.
It has to do with Ford's parts numbering scheme and parts ordering and inventory control.
The first version of a part may or may not have a -A suffix, to indicate it is the first version. You only got a -A when there was a later -B.
For example, the Brake Operating Pin is part number A-2075. It has no suffix. This part was never changed from the first design spec and dimensions.
Other parts did have an -A and a -B suffix. Many of them went to -C and beyond.
For example: A-3571-C Steering Gear Worm Bearing Roller Assembly.
And minor changes to a part would not justify going to the next letter, so they added a number to the suffix and you got -A2, -B3, etc.
Most of the time the new part design would work on both new and prior vehicles without a problem. If a car came in with a -A part that needed to be replaced, the mechanic could install a newer design -B part and it would work just fine (maybe better). So the -B part was manufactured from then on and the manufacturing of the -A part was stopped. But they were listed in the Parts Lists with the -A and -B as long as the -A was available. When stocks of the -A were used up, they were gone, and only the -B parts would be in the Parts Lists.
The problem arises when there is such a radical change between the -A part and the -B part that the later version CANNOT be used on cars that were originally made to use the -A part. The -B part just won't fit. So they had to keep making and stocking for service both the -A version and the -B version.
Ford's solution in the above scenario was to stock service Replacement parts for the cars that required the -A part, and in the Parts Lists they gave those service Replacement parts a part number with a -AR suffix (that is, a -A style part, for service Replacement, or -AR). Not for use on later cars that needed the -B style part. These earlier design parts were carried in the Parts Lists as -AR so that the dealers could order them when needed. They could also order the -B version, for the cars that needed that design.
Many of the really early cars had parts on them that were radically changed, as Ford improved the car's design (think brakes, wheels, headlights), and that second version of the part would not fit earlier cars properly, so these first style parts were in the Parts Lists with the -AR suffix to service the early cars. Hence all the "Model AR Vehicle" talk, and a persistent inaccurate urban legend was born.
Fun fact: there were also -BR parts! From the above, you understand that this was a -B version of a part that had to be used on certain vehicles, because the new, improved -C part would not fit. So they had the -BR service Replacement part also.
Example: A-3524-BR Steering Shaft & Worm Assembly - L.H.D.
Sorry for the long explanation, but it is the system Ford created. A bit complicated.
