I have a 52 F1 with a 239 and 3 spd on the tree. Dana 44 rear end.
From the day I've had the truck, the transmission would 'grind' going into 1st gear (non-sync?).
This past weekend, I decided to change the gear oil in my rear end. I've had the truck since April and not sure if/when the prior owner changed it. So I decided to do it.
No issues with the change - but since then, there is NO grinding going into first gear? When I start out, and I drop the truck to 1st (from a stop), it slides in and off we go.
IS there a correlation between the new gear oil in the rear end and the fact my transmission no longer grinds going into first gear?
Thoughts?
Rich
Thoughts?
Rich
