What Do You Make Of This
johnr9q@yahoo.com
I removed the cork seal on the rear main seal and it looks like a piece of the metal ring that holds the seal is missing?
Don't think you need to worry. Seems to be plenty of meat there to hold the cork pan seal without leaks.
Question: Was the pan leaking in that area previously?
One of the reasons you "bed" the cork gasket in Permatex No. 3 - to hold it in place while the cover is put on (which really holds it) AND to seal it.
Use a small 1/4" artist's brush and "paint" the permatex in the bottom of the groove. Apply to one side of the cork if you think it will hold it better.
Joe K
I don't think I ever used permatex in that spot. The pan will hold it in there tight enough.
Mike
It isn't necessary if you assemble the engine "upside down" according to Ford's methodology. But working underneath on your back, the "gookum putty" is an aid to holding parts together before the knife edge of the semi-circle cover can be applied.
There is a spray permatex product I use on the long pan gaskets when working overhead. I'm not finding the name - but it comes as a spray, goes on like a red translucent coating. You let dry to "tack" and then apply the gasket - which in theory holds in place long enough to put the pan up and catch it with a few bolts.
Joe K
