Epoxy came into wider use in the later 60s and is still the best insulator. Cheap coils may still have a liquid insulation. It pays to check on that in the manufacturers information if they have any.
x2 with master cylinder.
Alex, how do you test your coils?
The amp draw of the coil needs to be balanced with the life of the points. Higher amps, shorter life of the points. That's why in 12 volt systems a resistor is needed. More volts, means more amps pushed through.
A 6 volt coil is 1.5ohms. 12V are 3.0 ohms. Certain 12V coils have an internal resistor, they are usually marked as such, and then don't need the external ballast resistor.
A Standard Ignition UC14 6 volt coil is oil filled. The Flamethrowers seem to be epoxy.
Hotter sparks are usually associated with high compression engines, as the voltage needs to be higher to make the spark jump on the high compression. At 4:1 not much of an issue for a Model A.
Couple of corrections to your statements above:
- Not all 12V coils are 3Ω, I have one here that's 1.7Ω. The 3Ω coils are the ones with the internal resistor.
I've purchased my OEM replacement from Snyder's and it does fine.[/QUOT
Snyders is out of stock. CW Moss has them at 20.00. Sounds cheap so I'm back to my question. Should I go with a flame thrower. Or is flame thrower just a cheap coil with a flame sticker on it.. I'm runing a stock 4 cylinder motor with 6 volts.
