Re: What causes glazed brake linings?
Here's my update. I'd describe it as "mixed news".
I found that one of the rf brake adjusting shafts was binding in the adjusting housing, preventing it from smoothly sliding in its tunnel. I noticed that the center lines of the shaft and its tunnel were not quite parallel. I found that the roller plate at the lower end of the shoes (unique to floaters) could be moved slightly to correct the misalignment. [During installation of the floater system, the position of this plate is set by finger-tightening the mounting bolt and, with the drum installed, using the adjusting screw to lock the brake. It's done without regard to other things such as the alignment of the adjusting shafts, etc.] Thereupon the binding went away. Now the adjusting shafts move smoothly and one moves in response to movement in the other.
I checked the lf brake and found a much reduced version of the same condition. I made a similar adjustment and improved the smoothness of operation.
I removed all the glaze from the front brake shoes. There was a lot more glaze on the rf shoes than on the lf shoes. Since there was a lot more binding in the rf adjusting shaft than was the case with the lf, I suspect that the difference in glazing is related to the difference in binding.
I then went through the usual brake adjustment process and encountered different results between the two front brakes:
Left Front - I found that, with no brake applied, the brake dragged noticeably when adjusted to have severe drag in the 2" position on my brake board. Loosening the brake adjuster to eliminate the "no brake drag" resulted in no braking power at the 2" position. I could either have unacceptable free wheeling drag or no braking power! I suspected that the corrective adjustment applied to improve brake adjusting shaft smoothness might be responsible for this and reversed the correction. Now I could adjust the lf brake correctly. Interestingly, the adjustments applied (to either brake) were very small - I moved the offending brake shoe upward no more than 1/32". The moral of the story is that very small changes are meaningful.
Right front - I was able to adjust the rf brake so that I had l just a bit of drag with no brake applied and severe drag at the 2" position.
I then did a road test with these results:
1. Squeal is gone.
2. Good stopping power with no pull.
3. Rears lock up on gravel; fronts do not.
4. Front brake drums are moderately hot after a 5-6 mile drive with several stops; rear drums are cooler.
One reasonable conclusion, I THINK, is that the squeal was caused by the glazing in the rf brake which in turn was caused by heat resulting from brake drag.....caused by the misaligned brake adjusting shaft.
I am still getting some drag in the fronts, though noticeably less (measured by heat) than before - especially in the rf which seemed to be the primary source of brake squeal. I've made progress, but the results should be better. I see a couple of options at this point:
A. Have the front drums re-trued and their shoes re-arced and see if this improves anything; or
B. Switch back to the stock brakes.
Of course, the drag remaining in the front brakes may well bring about more glazing and thus more squeal. But for now, all's quiet.
Comments, suggestions and questions are welcome!
Thanks again for all the suggestions heretofor.
