Pat Martone
I would like to know what causes dirty points?
Also, how often should they be checked and cleaned?
I discovered dirty points when timing my engine via the light bulb procedure outlined by Les Andrews' Vol 1. At first I could not get the light to go out when the points were closed! Upon inpecting the points, the contact point attached to the points arm was dirty and had some scarring on it. After removing and cleaning the points with fine sand paper, the timing procedure worked fine.
I welcome similar stories and advice.
Thank you.
Thank you.
