Anyone know what year this is. Guessing 53 or 54, but best to know instead of guesse. Looked on E-bay and found one, bit by reading the guy selling did not know know for sure either. Thanks Rod
sorry to hijack this older thread but can anyone tell me how to remove this horn ring on a 54?
and is the wire from the horn ring supposed to short to ground or does it complete the circuit to somewhere??
my 54 has been converted to 12V but i can't seem to get the horns to work. i've purchased a 12v relay and non-stock horn to use instead but can't get them to work.
thanks!!
My Camel (Mike Hammel)
happy it worked out for you Barrygot it!! thanks everyone!! came off easily. there was a lot of corrosion so i cleaned everything up nice and tidy using 600 grit and steel wool. i found the center wire-followed it down to the old relay. i replaced the relay with the current design and added a small air horn (don't remember the name-maybe HOBO??). there was a 12v strip on the firewall so i took my power from there (i fused it of course). works like a dream. again my thanks for the tips!!
