Western Auto Wizard Side Bowl
TinCup
Well a rainy day at the Chickasha Pre War swap meet and I turned up this carb. If I understand it right the top is a Wizard aftermarket sidebowl top and the bottom is a standard Zenith2. The brass tag shows Wizard Improved and listed as it's from Western Auto. It appears the Wizard may be the same as a Simmons based on the pictures I have seen. Both pieces are in great shape and all passages are clear but they will not work together. I can always reuse the stock Zenith but without a matching Wizard bottom bowl it will just have to sit on the shelf until I can find one.
Funny how Wizard/Simmons parts seem to attract/accumulate Zenith parts?
Was the name Wizard/Simmons that attractive at the time? And was there some reason to want to experiment and mix/match parts?
I myself gambled and bought from Ebay an aluminum base Wizard/simmons carb that had an "unknown" (and unrecognized) cast iron top to it. I considered that the top might have been yet another Simmons variant - or something else?
On winning the auction and delivery, I found that the top was a Zenith top with the idle adust screw broken off flush with the casting and covered with dirt (and thereby rendered invisible to the Ebay camera.)
I was not happy - fortunately I had paid less than market for the carb.
My wizard/simmons bottom is in the pot metal style. So it probably won't help you.
Meanwhile, your cast iron Zenith bottom MIGHT go onto my cast iron Zenith top?
Anyone need a pot metal Wizard/simmons bottom?
Joe K
Joop I took this in BW because the brass tag is so reflective that it was hard to get a decent pic. It reads:
Wizard Improved
Patent Pending......
Western Auto Supply Co.
Hopefully I can find a good bottom to go with the top. I wonder if it will be tagged like the top?
A seller on Ebay is selling yet another simmon/zenith mis-match (I don't think I want to give it the status name of "hybrid.") See http://www.ebay.com/itm/Simmons-For...Parts_Accessories&hash=item58c122854d&vxp=mtr
This lower casting is unusual to my eye because of the "extensions" where the throttle shaft should be located (it and the disk are missing) It does have the GAV location - although what is in the hole is a bit obscured. But it does have the cast in "S" indicating that it is Simmons.
Is the "S" found on a Wizard?
Still, it might work - the price is sort of reasonable, and might bring back a carburetor variant.
Joe K
There is no S on the upper sidebowl unit. However the brass tag is in the same place. The Zenith 2 bottom that came with this unit is in good shape so maybe I can work a trade with someone.
Update!
Well I found a Simmons bowl on Ebay and while it was in horrible shape I was able to clean it up. The bowl was severely rusted and took quite a while to clean up. The main jets were there and I was able to use other parts for the missing ones. There is no tag on the bowl as I have seen with other Simmons carbs but there is a "S" stamped on it. I was glad that the Zenith Venturi was a match. I will be putting it on a test motor in the morning and we will see how it runs. The Zenith parts look like they will make a good carb.
Well I put it on the test engine this morning and it started right up. The float valve is still leaking so I will have to try and sort that out. I couldn't test as I wants as I was leaking too much. So Step 1 looks like a good start.
Running Wizard (Simmons) Carb
Nice find TinCup. I recently bought a complete cast iron Simmons carb (not the side bowl version) on ebay. I am now looking for a complete Simmons cast iron carb with side bowl for my collection. If anyone has one for sale I'm interested. I have an extra Zenith-3 side bowl that I might consider trading for a Simmons sidebowl.
