Thread Kits Company
Threadkits.com
310-891-1995 they’re in Carson,CA
They have other stuff like rivet nuts etc. nice company. I’ve dealt with them three times in the past two months. I bought TimeSert kits; 5/16 coarsekit, 5/16 fine tools to convert the coarse kit to fine, 1/4” kit. I wasted two days hunting for either keenserts or timeserts or the like. I’m not crazy about Helicoil. I will use one in a pinch but not in a spark plug hole
The Time sert bolt inserts get locked in at the bottom so they ca not back out. I don’t know about the spark plug seats.
I have KD spark plug inserts, they don’t lock. You put then in with the spark plug. You use blue Loc Tite on them. Time Sert kits come with a tool that you use to cut a groove with around the top of the hole.
Then there’s a tool that you use to screw the insert in with. The insert has a flange around the top.it fits into the groove and stops ot righ there. But the tool keeps turning a nd spreads the bottom of the insert locking it in place so it can never come out, you would have to drill it out.
The last three places I worked they never gave me spark plug with the can of anti-seize when doing plugs on any car, iron or alloy.
We used a square caged fan to coll the engines quicker before breaking the plugs loose.we just laid it on top of the engine. It doesn’t take long
I
