There is an article in Rod and Custom magazine about 1953 0r 4 on a guy whou successfully built a six cylinder Model T Ford, I think just to see if he could. I believe the car still exists and runs...
He cut up at least 2 blocks and several each crankshafts and camshafts...preheat was a really interesting bit: He built a firepit for the block, aligning the pieces with angle iron, then built a custom furnace by stacking fire brick around the lump. Once everything was sizzling, he removed a few bricks at a time and welded the exposed area, restacked the bricks, and moved on to another area. Once he was done, everything was left in the furnace til it burned out and cooled off.
Shafts were rewelded into proper 120 degree type formation, engine was assembled and ran fine.
So...a welding genius with excellent improvisational skills can do just about anything.
The article is worth seeking out, and last time I posted about it someone put in information on the car's more recent life.
