I intend having the flanges ground for a good surface onto which I will shrink the weights and the middle two will be about 10 thou larger than the end two so that the weights can be threaded on while cold."END QUOTE"
That won't work Mr.Synchro, you have to cut number 4 first, and then 3,2, and 1, last, and assemble, 4, 3, 2, 1.
The weights don't need bolts, two 3/16 pins are are good enough, and they don't even need that. Then just air hammer the holes shut, just like Fords.
Weights should be 5/8's thick.
Herm.
