bmwillia
I have a weird fuel pump issue.
I am installing the fuel pump with the pushrod at the top of its stroke. Before I put the nuts on the posts I can push the pump stand down several times and fuel pumps into the bowl and out the pump towards the carb.
From that point, without removing the stand from the studs, I put the nuts and washers on and tighten them down. Then when I crank the engine, I get no more fuel into the bowl or toward the carb.
Any ideas?
Any ideas?
