Weight carrying capacity in a 32 pickup
hb32
In the process of selling my pickup and it’s tentatively going to Germany. Buyer is also buying a flathead and plan was to ship it in the back of the 32. From the builder, 600 lbs +/- a couple pounds with crate. Haven’t found anything on the weight carrying capacity of the old girl. She does have new reverse eye springs, and 750-16’s on the rear. Just don’t want to overload. Thanks
I have brought home over 600 pounds of concrete on the running boards of my model A
it is stock, with yours it would depend on the modifications, should be able to handle it, how far is it being driven?
I've had 5-600 lbs in the back of my deuce pickup several times since I got it. Mine has a New Posie 40 rear spring. No problems. I would be worried that the weight in the back for the duration of the trip might cause the spring to take a set and not rebound when the weight is removed?
Thanks for your reply. From what I understand it would be about a 6 week journey. I would think that the load position would also play a factor. Would it be better loaded as far forward in the bed to distribute the weight between the springs? Posie original style spring here as well in the back and front.
Jack the frame up a bit leaving the rear end hang down, then custom cut a block of wood to fit in the center between the U bolts so it can't move, let the jack down, ship it.
Great idea and not sure what roll I will play in the loading of the pickup
This engine rode around in the back of my 32 pickup for a whole summer so I would not be worried
I agree with uncle buck. I would probably make a custom fit wood cradle and screw it down to the bed and ship it.
On exhaust mount engine stand, strapped down. Avoided speed bumps and made it home. The rear end under that '34 is from a '71 pickup, and the shackle bushings did not survive. Plastic crap came with the rear end kit.
