TommyCoupe
It's only noon here in CT, and already I've had my @$$ kicked by this car.
I've been having electrical/generator problems, which I though I had licked. Went out this morning and polarized the generator and started the car up. The ammeter may have moved a small amount when it was running, but if it did move, it was an insignificant amount. Revved the engine for a while and still no major movement.
Turned it off and measured battery voltage. 6.14v not running.
Started the engine again and voltage at the battery was 6.08.
The voltage at the cutout was 6.14. So my guess is that the generator isn't working.
Just before I shut the engine down again, I notice a lot of steam coming out of the overflow tube. So great, now I'm thinking I have a timing problem or carb problem, or who the h#!! knows. Probably someone on the barn would know, but today I'm just too stupid.
So, OK. Let's forget about that and move onto putting some glass in the car. I started on the passenger side quarter window. Just as put the last screw in, I hear a little snap sound, and a nice crack runs right down the middle of it.
Another lesson learned the hard way. I should start a thread listing all the things I have learned the hard way, so other people can learn from my stupidness. (Is that word ?)
So, OK. Let's just put it back in the garage. Got in the car, stepped on the starter button and the starter barely turns. I checked the battery voltage, and guess what. It was 6.14V.
Then after I struggle to push it into the garage (uphill by myself) it starts drizzling outside. The car kind of needed a cleaning anyway, but it just made it harder to get into the garage.
Finally got in the garage, and put the battery charger on it. Battery level looks low, but there aren't any meters on it or anything so I don't know what the real voltage is. It just says "charging 25%".
I'm going to go out and put the old 1970's SEARS charger on it and see what happens. I believe that one has an ammeter on it.
So, for today I am defeated. I won't get far on this car working just the weekends when things like this happens.
Ever have one of these days ?
Tommy-
Tommy-
