While I wait for Sam at Arizona Ford to answer the phone, I thought I would ask here. Sam is very helpful, but he's a busy guy.
We are having some issues on the Weber 32/36 (we got it ten years ago or more from Sam).
It seems to idle fine, but when you stomp the gas pedal, it goes into stall. It's sucking air at this point, and can and will backfire.
We replaced the power valve. Have a carter fuel pump on it from Sam along with his lines.
In the bowl, you can see gas percolating through regardless of the engine running. A push of the power valve shows one side spraying. Is the other bowl supposed to get a spray too?
So many theories on it's timing (we set the timing).
Here is a video of what is happening.
https://youtube.com/shorts/JxhKehHganw?si=pc8Ru4VqLmfFUE6B
Thanks for the help!
