One thing that ALL the '54 engines have in common is that they use a tang/slot type shaft to drive the oil pump. This carried into early '55, when it was superseded by the "hex" type shaft. This can make things a bit complicated if you want to change either the distributor or the oil pump, as the early pump is no longer available new. For most Y blocks, you can either switch to a '57-later distributor (a good idea) or at least swap in a '55-'56 hex drive dizzy.
However, there IS no 13-tooth hex gear distributor for the Dearborn, so you either have to keep the early pump style.... OR... you can, however, use a later distributor in the Dearborn, if you swap the gear to the early 13-tooth gear. Keep in mind that to do this for ANY '54/early '55 Y block, you also have to get the hex intermediate shaft, and a later oil pump, so it's a bit more involved than a simple dizzy swap.
https://www.jalopyjournal.com/forum/threads/239-y-block-question-s.245502/
