rotorwrench
The day that an engine was built is likely an approximate but is likely close enough. Depending on where the engine was bedded into a frame may add a lot of time to a build date for the car as a whole.
Tom, I'm wondering where you had to check to find out that your new "A" is a female?
Beautiful automobile by the way.
I had this issue earlier and it was my ignition coil. I was driving fine and it suddenly quit. I had fuel but didn't seem to have spark. Using a test light, one side to frame, and the other to each side of the coil. I had light on one side and none on the other. Replaced the coil and voila - light on each side and immediate start.okay, Margarethe and i had our first problem. She didn't want to start, smell of fuel was there but no ignition. I had a long, hard think about it and i assumed that it must be the distributor. What did i find? No connection between the distributor cover and the plate below it. See photographs. Worn and used up metal in 91 years? The new distributor is ordered and the tdmporary fix is a bit of copper grease on top the metal lid and under the cover, giving better connection between the two parts.
Should this little dab of copper grease be part of the routine service work?
It looks like an outstanding, well maintained Model A. However, I would do a complete lubrication before you take it out on the road keeping your eyes open toward future restoration/maintenance projects. Have fun, I have been in this situation before. I feel bad for other motorists who have never heard the sound of the Model A as it starts out in first and on to second gear. It is the sound of pure reliability. Ed
I have a short term certificate right now and i have driven about 80 miles with her. What i do notice it is a misfire when the engine is being pushed, like down a hill or even during shifting. I have opened up the gav but i was not under the impression that that helped.
check your timing on the column.......
