Do a search as this was covered recently. If a 2 blade fan you should be able to get the pump out WITHOUT removing the radiator. Loosen radiator rods, remove hood, undo top hose connection, tilt radiator forward towards light bar, INSERT piece of cardboard to cover face of radiator, remove 4 w/pump nuts, fanbelt, remove pump. Others may have different suggestions. If you rebuild your pump fine, if not get a good leakless AND the new 2 blade aluminum fan.
Paul in CT
