Thanks Frank, the end of the water pump shaft is not exposed so nothing for my gear puller to push on. The end of the water pump shaft is covered by the fan shaft/flange.
Thanks Don, do you guys know if the fan clutch shaft/flange and pulleys are one piece or two, I can't tell and it doesn't show one way or the other in the factory manual. I thinking maybe some heat. I'm almost in "just get it apart mode" because I'm sure if I pry any harder I'm going to bend or break something. I've removed the radiator and a/c condenser so not to poke holes in them. All of this just to get the a/c compressor mount off to remove power steering pump for rebuild. Transmission and torque converter was a piece of cake to r and r compared to this deal.
Just going to take a little time away from it and watch the truck race and then get back to it. Thanks for all your thoughts and anything else you can think of please post. Doug
