30Tudor
I am considering putting the modern bearing race and shaft sleeve supplied by Brattons on my waterpump. Does anybody have any experience with these they could share? How difficult is it to get the sleeve on and what happens if I ever have to replace the rear seal?
Here is the discription.
This set has a hardened sleeve which you press on your W.P. shaft (your shaft must be .625 diam.). The matching internal needle bearings roll on the hardened sleeve. The tolerance on this set is better than the original giving a smoother roll and less vibration. If using an alternator, this bearing will withstand the additional load better than the stock bearing. This set is the same size as the original bearing and sleeve. Instructions included.
