1931 flamingo
As was asked many posts above, what are you going to use the grease for??
Paul in CT
Paul in CT
Paul in CT
This is a joke. As you noted he has refused to answer the question that many people have asked.
All he has to do is Google the question and he will get his answer. I Google it and I don’t think it has anything to do with Model A’s.
I’m moving on.
David Serrano
Paul in CT
The fitting on the rear bearing of the water pump has a cap on it. I put some lube in the cap and screw it on, forcing lube into the bearing. With a good bearing, you will feel the resistance. I give it a half to one turn when I lube the distributor. (about 300 miles) If you think that is not enough, I suggest running a lubricating additive in the water, Like the Cyclo one I mentioned above.
I use K-Y jelly in a lube cup
Take your grease gun and give it 1 pump and measure the amount of grease that exits. Use the amount as a judgment on the number of pumps needed usually 1 or 2. Just don't take it to the local garage for a lube job! Want another grease area to worryt about? The zerks on the rear axle shafts need the same care in not overgreasing. 3-4 pumps there are all that is needed.
Use chassis grease was my recommendation! The grease fitting was added for a reason, not for ornamentation.
If I do not find what I am looking for......
